Sat, Sep 21, 2:52 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 12:48 pm)
Subject: Making Water
gusdrum ( ) posted Mon, 17 February 2003 at 8:34 AM ยท edited Sat, 21 September 2024 at 12:00 PM
How can make the "Animated displacement" in a static plane with reflection for build animated water? I need suggestions. Tanks.
Little_Dragon ( ) posted Tue, 18 February 2003 at 8:12 AM
I assume this is for Poser 5? You'll either have to play around with procedural shaders, keyframing changes in their values, to create a wavy or ripply effect, or create a wavy/ripply water animation (.avi or .gif format) and apply it to the Displacement channel through a Movie shader.
Little_Dragon ( ) posted Tue, 18 February 2003 at 8:58 AM
Example:
Here's an animated ripple map.
(You are getting sleepy, very sleepy ....)
Little_Dragon ( ) posted Tue, 18 February 2003 at 9:02 AM
And here's the result, when applied as a Movie shader to the ground plane's Displacement channel. I added a reflection map, transparency, and a reflection shader (for a true reflection of the column) to make it more visually interesting.
gusdrum ( ) posted Wed, 19 February 2003 at 10:20 AM
Tanks for your help. Your final result in amazing.
