Havent looked yet.. but off the point on my head. it looks like it pointing at you. then i assume ? that twisting the forearm / then/ the wrist to match flat like .. or the deafault pose ..arms out to side... pull them to the front like a zombie then twist the forearm flat and match the wrist cause the anomally ?
uh, the hilt would be in line with the index finger and the rest of the fingers would be grasping nothing? With a foil or ep, the hilt would align parallel with the extended thumb, and be pinched with the second joint of the index finger, with the rest of the fingers cupped around it. (IIRC from those fencing classes in college so very long ago)
The finger extended along the top of the blade is a standard variation of the 'curving' the index finger around the front of the hilt, considered the 'starting' grip for the other position. And yes, maybe the fingers are grasping 'nothing' but I was showing that's about as close as the hands seem to want to go. It's as close as I can get from playing around with one of my swept-hilt rapiers and trying to duplicate the grip. Of course... you could always use a bell-hilt and solve the entire problem 8-P If you can't see it, it ain't there, right? And yes, the hilt/blade is in line with the index finger using that type of sword, since that's the logical extension of the arm. I won't argue with how you were taught, but I can agree to disagree.
Awesome, I didn't even think about doing it that way. I was trying to mimic something a little more drastic with the wrist, which by the way, with Limits on you can do anyway:) I think I'll have to use the bell-hilt as you suggested. There are always solutions out there, isn't there:) Thanks for getting me pointed in the right direction. ~ brent ~
D'oh! Westley. Nance, that is exactly the pose trying for in your last post. Something you said about the additional joint in the palm was something I hadn't thought about before. After I read your post I picked up my sword and studied my hand a little more (ok a lot more:)) and I saw exactly what you meant. I was trying to accomplish this by going over board on the side-side of the wrist and that's where I was running into the problem. I'll have to check out that web site to get a couple more ideas on some hand poses. Up until now, I hadn't realized how difficult posing the hand could be:) Thanks again for the wonderful input! I'm off to break some wrists again:) ~ brent ~
Attached Link: http://www.3dmenagerie.com/
heyas; try my grip hand poses; one is a power grip, and one is a dex grip. the dex grip angles the fingers so the gripped object lines up better with the forearm. try it yourself: grab (or pretend to grab) a hammer to hammer some nails. you hold the hammer perpendicular to your arm. you can't side-side your hand 90 degrees to get it to point along with the forearm. now grab (or pretend) a screwdriver to drive some screws. you can point the screwdriver more parallel to your forearm by a little side-side and doing a progression on the fingers... aw, just go download the grips! :)This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
