Thu, Dec 26, 8:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Poser 5 Help please
ladynimue ( ) posted Wed, 19 February 2003 at 11:01 AM ยท edited Sun, 03 November 2024 at 5:48 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12419&Form.ShowMessage=1109261&Reply=1109938#3
HI everyone.. I need your help please for a Poser 5 and Print realated question that was asked in the Print Forum (see link above). The member wants to know about Rendering in Poser 5 and how to set the Render Settings. He wants his final output to be 8 1/2 by 11 inches and preferable to be 300dpi (for printing). Thanks for your help :) ladynimue
amon_g ( ) posted Wed, 19 February 2003 at 11:16 AM
I would try a width of 2550px by 3300px at 300dpi and see if that does the trick. Hopefully this helps. I'll also post this in the print forum. ~ brent ~
ladynimue ( ) posted Wed, 19 February 2003 at 11:23 AM
Thanks brent... I am not sure if he needed the pixel info or the instructions on how to resize the Render Window in Poser 5. I appreciate your help :) ladynimue
MaterialForge ( ) posted Thu, 20 February 2003 at 1:10 PM
I wouldn't resize the main render window - follow Brent's suggestion for resolution, but put those settings in the "Render to New Window" option in the Render setup, and check that option.
ladynimue ( ) posted Thu, 20 February 2003 at 2:09 PM
Thanks silver... :)
amon_g ( ) posted Thu, 20 February 2003 at 2:17 PM
Well, the reson I recommended resizing the main render window was so that you could get an accurate preview of the final output. I normally have my main render window set at 1024x1024 and then I'll kick off a render in a new window at, let's say, 800x600, well what typically happens to me is that the top/bottom of the image usually gets cropped simply because the final output doesn't match the main render window. The 638x826 I recommended for the main render window is a quarter of the final output. Again, this is something that I do just to help me out with the composition.
amon_g ( ) posted Thu, 20 February 2003 at 2:18 PM
Boy o' boy I wish this had a spell check:) reson = reason ~ brent ~
