Tue, Feb 11, 7:06 PM CST
Subject: poser to bryce
zackm17 ( ) posted Thu, 20 February 2003 at 8:04 AM · edited Tue, 11 February 2025 at 7:01 PM
HOw do I make poser hair look like poser hair when I import the image into bryce. When I do that the hair looses its transperancy map or something becuase the hair in bryce looks like the entire hair object is just textured with the colors of the hair. What I'm trying to say is that it looks solid, and no longer like it did in poser. please do help, thanks
c1rcle ( ) posted Thu, 20 February 2003 at 8:30 AM
add the transparency in the second slot then choose Blend transparency from the dropdown, make sure you turn refraction off tho, not like in my pic.
c1rcle ( ) posted Thu, 20 February 2003 at 8:35 AM
here's another try, still blend transparency tho :)
Patricia ( ) posted Thu, 20 February 2003 at 11:28 AM
So it doesn't matter what random texture comes up in that second set of windows?
c1rcle ( ) posted Thu, 20 February 2003 at 11:35 AM
sorry should say you need to have the texture in the first one then replace what comes up in the second one with the transparency otherwise it wont work. I didn't have any poser hair to hand when I did those pics earlier, I'll be better prepared next time :)
zackm17 ( ) posted Thu, 20 February 2003 at 11:59 AM
I still can't get it to work, I dont know why?? im using kazaburo hair and its just not comming out the same in bryce. Sorry im kind of new at this Ive only started using these things a few week ago Here is what I have in poser and what i want in bryce
zackm17 ( ) posted Thu, 20 February 2003 at 12:00 PM
here is what i get in bryce, notice that the hair looks like a solid object, not like the poser image were the bottom of the hair look somewhat like strands
Barryw ( ) posted Thu, 20 February 2003 at 6:32 PM
Load the texture in the first block. In the second square BESIDE the texture hit load and find the trans map. You might need to click on the half black half white circle to reverse the trans map. You don't need to load a second texture for the transparency. Hang on a second and I will make a quick pic for you.
Barryw ( ) posted Thu, 20 February 2003 at 6:46 PM
Okay here goes...
Barryw ( ) posted Thu, 20 February 2003 at 6:48 PM
one more, Sorry if these are too big for slower connections. Just make sure that you have blend transparency like the second post.
zackm17 ( ) posted Thu, 20 February 2003 at 6:51 PM
I finally got it, thanks for all the help guys....
c1rcle ( ) posted Fri, 21 February 2003 at 3:53 AM
oops so much for me trying to be helpful :( at least I got part of it right I suppose. ducks for cover
