Hi folks,
This is cool stuff, with Brian's new Gradient Shader, I took the Dead Moon from the Shader Ops resource page and in just a couple of minutes turned it into a planet!
Check it out.
Best regards,
Eric Winemiller
Digital Carvers Guild
Freeware and commercial 3D extensions
http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
I'm also very interested in the Tracer... is it anything at all like "PhotoModeler?" I realize PhotoModeler is a very detailed piece of software, but to be able to create models from traced photographs would be great. Brian, do you have any examples you can show us... IE: a model you have created and the photo you used to create it? Thanks. Chuck
Attached Link: http://www.konfabulator.com/
Looks great. The Tracer option would be very useful. As I understand it it is a floating image on top of the Carrara interface. Does this mean the user can adjust the transparency of the image? Quartz in Jaguar (Mac OS 10.2) should allow for that. Konfabulator.com has a very cool XML/javascript program that would allow to create "Widgets" for this sort of thing if you can get it to run on top of the Carrara UI.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Lost Horizon Software (www.losthorizonsoftware.com) is proud to announce the availability of the Power Pack Ex. It is a collection of 5 plug-ins that provide Carrara with some much needed extra functionality. It is priced at $29.95. Any purchaser of the original Power Pack can download and use PPEx for free. Here's a brief description of the plug-ins - more information, the docs, and some renderings are available on our web page. Tracer Allows 2d images to be loaded and traced over Gradient Shader Add powerful coloring to procedural shaders, similar to POV-Ray's gradient capabilities Blurry Reflections Create realistic blurred reflections Fresnel Effects Simulate the reflection and transparency properties of real glass. Particle Sprites Creates more believable particle effects by forcing them to face the camera at all times and allowing proper texture mapping. Brian Retford Carrara Extensions www.losthorizonsoftware.com
