Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 07 6:58 am)
The same ethos applies to the actors and dials sections... you can edit, add and remove lines from the cr2 without searching through huge text files...
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=9540
Oh... just in case you're wondering what happens when you click on the little buttons like "Edit sphere mats" etc, here's a view of the popup you see when you click on "Edit erc/emc"... A bit of a silly example, but you can see how easy it is to set up here!I forgot to include the link to PBooost!
Here it is.
Er... It already works with XP, procci. Has done since 1.3! With NTFS drives and clean texture references all works. MysticW... Unfortunately, CL wouldn't let me patch Poser to fix the bug... Poser has the bug, not PBooost:) CorrectReference sorts out the dodgy paths so Poser doesn't do it's lock bug thing. The majority of PBooost's users run XP-NTFS as an OS (using Poser 4) and have no problems with the system at all! H:)
Only problem I have with PBooost is that I can't figure out how to use it LOL Unfortunately I have a feeling that I can't blame PBOOOST for that..... I use it for tidying up my folders though, and I'm happy to have it. It's a great proggie. Now if only I could figure out this switch banks thing...
Attached Link: http://www.horseless-headsmen.co.uk/HHTuts.htm
LOL! I've tried to keep things simple... have you looked at the tutorials? I've included the link to the tuts here... they're fairly comprehensive! H:)Uhm tutorials? There are tutorials? well ta-dah...just pretend I never said anything, ok? =o)
