I can import 3DS just fine in Bryce5 on my windows pro system. I can't import 3d studio max files. Also, most files are zipped and you have to uncompress before importing. If your file has a .zip extension get winzip or stuffit. The free versions work fine for unzipping. Stuffit will also handle Mac .sit zip formats.
well, i tried it, i downloaded various 3DS versions of the models on this site: http://www.theforce.net/scifi3d/starwars/alliancecraft.html but they all give this error: "an unexpected error has occured(invalid format) btw, i have to select "all files (.) to see the 3ds files when i want to import them. maybe yuo can give me a link to a model that does work with your bryce, so that i can test it.
Attached Link: http://www.3dcafe.com/asp/meshes.asp
lots of free 3ds models here. You might want to try .obj format and see if you can import that format also. I don't remember if the patch had anything to do with importing files or not but if you havn't installed it yet you might try that.heck, my preferred import format is .3ds. I try to use them whenever possible, tho I've also imported .dxf and .lwo, with no appreciable problems (other than them coming in upside down, which I suspect is just a difference given to primacy of XYZ coordiates). Haven't tried the Force.net stuff yet (even though I've got..oh.. about 60 megs worth..;). Try downloading again, and make sure you get the .3ds ones..I know the site does have several versions of most of the models. I've downloaded .max ones by mistake..
To import bryce-native formats you should use the little triangle next to create and then use the import function. If the format isn't a bryce-native format you should use files/import object.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
Yes do as Ang25 said, use the import under the file menu. Where you were is to import .obp files which are bryce native obect files. Other native files are .mat which are material files and accessed by the triangle next to "edit". .bsk are sky files, little triangel next to "sky & fog" all others are imported under the file menu
hello everyone, i'm new here, and i recentely started to use bryce 5, but when i search for models, almost everything is in 3ds format, wich i can't import to bryce, but on every site is visit, 3ds models are for bryce too, now do i need a converter to convert them to obp format, or is it just not possible to import a 3ds?
