Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
Thanks Sharen.. I will let Dav know. Thanks Guitta. You can also select which ones to change, you don't have to change them all. We also use it for Poser when we want to make thumbnails for poses. Makes it a lot easier to grey out the figures in poses for couples to show which figure each pose effects. Lynn is open to suggestions for tailoring it for other uses. It is a WIP. At some point it will be upgraded to a windows program rather than command line.
Guitta...please bear with us. This is our first free item, and we are still shaking the bugs out of the store software that handles free items. Once we get the download software working, we intend to start having many more free items, some of which may appeal to you. Fixing the problem with the download software is difficult, because so far, none of us who maintain the store have been able to make the problem happen. (But our tech guy is putting in some debug code that will help next time it happens.) Thanks for your patience. lynn
Attached Link: http://www.castledevgroup.com/modules.php?op=modload&name=Downloads&file=index
Thank you, Daemonsbane!!!!!! That was the missing key piece of information. The real problem is that the URL got truncated when we posted it. It is slightly longer than the "post a reply" page can tolerate. The real URL ends with "cid=5" rather than just "cid". Or you can click on the URL on this post, then select "Vue D'Esprit". I apologize for the confusion. Lynn Grant CastleDev Technical SupportThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Attached Link: http://www.castledevgroup.com/modules.php?op=modload&name=Downloads&file=index&req=viewdownload&cid
The Poser PZ3 color changing utility is a Windows command-line utility program for changing colors in Poser CR2, PP2, PZ2, and PZ3 files. Its primary function is to change highlight colors from black to white when using Poser PZ3 files in Vue dEsprit, but it also has several other function. Full instructions in PDF ReadMe file. Version: 1.0 Filesize: 343.75 Kb
