Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:08 am)
If you've got Tailor, you ought to be able to transfer the settings, then put the dial at negative the amount on the suit to get it to fit the default shape. It can work pretty well on some clothing. I use it on the Wusamah stuff for Mike (requires a thin setting pf .5). After I added the thin morph via Tailor, I loaded it up, conformed it to Mike, and set the thin setting on the clothing to -.5 and it fit very well. A little tweeking, but not much.
Using Tailor to morph the suit to fit default V3 worked pretty well. The suit is built for the ThighWide and WaistNarrow morphs set to 1. I have the suit fitting V3's default waist and hip. I forgot to check the breasts. It looks good with BreastSize6 set to 1. I'll post the render sometime tomorrow. It's time for bed :)
The right render is V3 with her default body shape, except for the breasts. Somehow, I missed the breast setings last night. The Catsuit has a V3Base morph, transferred using Tailor, to adjust the hips, thighs, and waist to default. I can account for the breast settings tonight and see how it affects the open morphs.
Eowyn,
The Tailor works just great on V3. It does not CR2s created with Poser 5 though. I just load custom character Cr2's into Poser 4 and save them before I use them with Tailor.
Raise your hand if you find yourself wishing Billy T's latest items fit V3 in her default shape. (Hand Raised) -WTB
