Wed, Jan 8, 8:53 PM CST
Subject: Peppers Ghost
runwolf13 ( ) posted Thu, 27 February 2003 at 5:07 PM · edited Wed, 08 January 2025 at 1:27 AM
Here is a quick render of a Pepper's Ghost from the tut ShadowWind posted here. Very handy tut, btw. I'm not really happy with the results. Haven't figured out how to get only portions of the ghost to show, such as the lower portion fading out. Also, I didn't realize that the Marlene model was SO BAD. But anyway, just playing around.
ShadowWind ( ) posted Thu, 27 February 2003 at 7:48 PM
Thanks for trying out my tutorial. I think it has to do with the lighting that you are using on the ghost side. What light are you using? Usually ghosts are done with spotlights that have very tight beams and in Vue it's necessary I've found to make the softness a bit higher than normal to get that fade off.
I'll check back here and I'll be glad to help you with it...
ShadowWind
runwolf13 ( ) posted Thu, 27 February 2003 at 9:43 PM
The spot on the ghost side is a quad spot, with a spread of 5 degrees, power of 5 and a fall off of 50%. It's in fairly close, dead front of the ghost and up high. For whatever reason, the Quad Spot won't let me put in a softness variable. Should I change to a regular spot?
runwolf13 ( ) posted Thu, 27 February 2003 at 9:53 PM
Okay, I deleted the quad spot, and here is what happened! The Ghost is still strongly visible, and there is NO lighting on the ghost side of the glass. Huh?
runwolf13 ( ) posted Thu, 27 February 2003 at 10:08 PM
Okay, you gotta turn the ambiant light off... this is better, but not yet there.
ShadowWind ( ) posted Thu, 27 February 2003 at 11:25 PM
Yeah, that has to do with it. I usually enclose the ghost side in a box made up of walls (not within a cube) that keep the light from getting to the ghost while keeping the other side lit. You might try that...
ShadowWind ( ) posted Thu, 27 February 2003 at 11:27 PM
The walls should be flat black with no ambience or diffuse. I didn't shut off the Ambience for Misfortune Teller, so I didn't put that in the tutorial, but it is important to keep light off the ghost side except for the spots...
ShadowWind ( ) posted Thu, 27 February 2003 at 11:28 PM
You should be able to add a spot at wide range toward the girl to lighten the scene up on the solid side without effecting the ghost side. You can use multiple spots to light the entire room...
ShadowWind ( ) posted Thu, 27 February 2003 at 11:29 PM
Hope this helps...
TheWingedOne ( ) posted Fri, 28 February 2003 at 6:38 AM
Where can I find the ghost tutorial? Phil
ShadowWind ( ) posted Fri, 28 February 2003 at 7:53 AM
Attached Link: http://www.shadowwindmanor.com
Right here. And then pick tutorials from the top bar. There is one for Vue and for Bryce.
TheWingedOne ( ) posted Fri, 28 February 2003 at 10:13 AM
Many thanks! Have to give it a try someday. Btw. your image "Misfortune teller" really rocks!!! Phil
ShadowWind ( ) posted Fri, 28 February 2003 at 10:30 AM
Thanks WingedOne. I added the ambient light comment into the tutorial so others won't have trouble runwolf13. Thanks again. ShadowWind
runwolf13 ( ) posted Fri, 28 February 2003 at 3:52 PM
Thanks ShadowWind. I'll work up some new models and stuff and see about trying out the technique on something more "substancial" than the objects in Vue! Thanks again!
