Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
ok i am confuzzled here. I bought IPB and i do not have the pose file. My copy of IPB says 2. Apply the REM poses to remove the Morph Delta's from the figure. This cuts down on file size and processing time. The figure will revert to the default morph, but the dial settings will still be saved. the daz site tutorial says : 2. Apply the REM pose "! IPB Prep" from the !DAZ's Victoria 3 category of your Poses Library to remove the Morph Delta's from the figure. This cuts down on file size and processing time. The figure will appear to revert to the default morph, but the dial settings will still be saved. Do not use this poses unless you intend to create a readScript pose from the CR2 using IPB. Have I gotten the wrong file or something??/
wdupre, Thanks :) I have it bookmaked! Now it makes sense to me!
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
oh god, please no! cries you know, in order to get v3 to fuction on the laptop properly (320megs ram, 12gig drive) I had to move out all but 2 injection folders from the pose directory :/ does this mean more products are going to be coming out with them horrid morph injectors? if so its seriously going to be putting a damper on my buying habbits.
Thanks all for the comments. :) Dark Faction if you are removing INJ pose files you are not removing much at all. the major memory hog is the fully injected V3. what this program does is allow you to load a V3 with only the morphs you want at the point that you load your figure. no more storing huge CR2s. the injection system is actually far more memory efficiant then the old V2 system. Will
Attached Link: http://www.willsmind.com/IPB-tute.htm
for anyone having difficulty figuring out INJection Pose Builder by DAZ. or just want to get a feel for what it does, I put together a basic tutorial. by the way there is a slight bit of nudity in the tute.
