Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:57 pm)
If you're wanting to buy V2, buy the CD because it's much better value than buying V2 alone, then adding clothes, hair, etc. There are boatloads of stuff (free and otherwise) available for V2, and most of it will fit Stephanie too, should you ever decide to buy that model. If you're wanting V3, make sure you have a fairly hefty system, don't forget to buy some of the morph packs and get hold of the free "Dial Cleaner" utility from DAZ. Dont' forget the SR1 packs, too. Quite a few people have recommended buying V3 as an upgrade, once you have V2, since it seems to be more cost effective.
You don't have to buy them all, you can go either the upgrade route, which seems pointless to me personally, as each is an improvement on the previous model, or just buy victoria 2 or 3 (whichever you prefer.) Have you gone to Daz3d and looked at the information they have there? That might help you Shanna :-)
V1 and V2 is basicly the same figure: they share the same obj file. The only difference is that V2 has more morphs. In reality that means that if you buy V2, you have V1 as well without even knowing it... V3, however, is a totally new figure with a new obj file. "Upgrading" to V3 is actually installing a totally new figure, it does not touch any V1/V2 files. The upgrade price is just a marketing thing and the "V2 to V3" upgrade package just makes sure that you have V2 installed before it allows you to install V3.
I faced the same question about 5-6 months ago. Note I had the $$ (at the time :-)and invested in the DAZ Vic2 CD & Mike2 CD + the V3Base, Head & Body morphs. I used Vic 2 a few times and V3 ALL the time. I would go straight to V3Base with Hi-res textures, + the Head & Body Morph Packs. Mike 2 is the Guy for now but I will probably go to Mike 3 if he's as good as V3. I consider my Vic2 Cd purchase a waste of $$. Opinions may very Also V3 likes a BIG machine.
What should I know before puchasing some version of Victoria for Poser 4? Thanks much, Steve
