Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1130371
It allows you to create extra folders in Runtime which it accesses by bank switching. For example, in Pose I now have PoseDefault, Pose V3, Pose Vicky Poses, Pose MAT Poses, Pose Misc. Poser only sees one of these at any one time, the rest are hidden from it by the code within PBoost. You can, however, switch from one bank to another on the fly, provided all your internal file references are squeaky clean. You can find more about that in an earlier thread...Coppula eam se non posit acceptera jocularum.
Like Sam said you can have as many different folders as you want & switch them in & out whenever you like, right now I have 16 different pose folders I can swap between while poser is running & I haven't lost a single one yet. Taking Sam's folders as an example, if he's using PoseDefault at the time he's using it it's called pose, when he switches over to pose V3 that will be renamed to pose & the other will be renamed to PoseDefault. I've had PBooost since August last year & it's really one of the best purchases I've made since I started using poser.
Attached Link: The Netherworks
I use XP home with NTFS & it works fine but you should try the compatability test run CorrectReference on your runtime then try the test again, CorrectReference is hosted by Netherworks.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello. Have P4 and propack with a lot of things installed in my runtime directory, i was looking at PBooost... It seems good but i was wondering how it works? Does it actually dynamically change the names of the different folders to hide the unwanted ones in P4? If so, isn't it a risk of messing the whole runtime on a crash or so? Looking for some users feedback, thanks :)
