Tue, Feb 4, 5:15 PM CST
Subject: poser propack
ldtroisd ( ) posted Wed, 05 March 2003 at 4:26 PM ยท edited Mon, 27 January 2025 at 10:10 PM
2 questions please
I'm french
---I buy poser 4.0.3 and pro pack english
i have a PC with XP PRO and i cant install pro pack(english)
(is it possible propack doesn't goes on with XP)
---with the cd the plug in light wave is for V5 to 6.5
where is the plug in for 7.5 please.
thanks
pink999 ( ) posted Wed, 05 March 2003 at 4:43 PM
Do you have a downloadable version of PP or the boxed cd? Also what exactly happens when you try to install the propack?
casamerica ( ) posted Wed, 05 March 2003 at 5:09 PM
I wish I could help you more, but I use Poser 4 and Pro Pack with WinXP and have had no problems. Is your copy of Poser 4.0.3 also English? I believe I remember there being an issue with trying to mix the various language versions of Poser and Pro Pack. Take care, be well, keep flying. casamerica
ldtroisd ( ) posted Thu, 06 March 2003 at 12:36 AM
1/i open pro pack set up
2/the window install is open i choose next
3/then a window (the installer will search your systeme for poser 4.depending of the size of your hard disk)then OK
4/ a window (searching for poser )
and the install stop
the window to send a rapport to XP OPEN
IN THE CD THER IS
3DS PLUGIN INSTALL
DAZ PRODUCTIONS
DOCUMENTATION
FLASH EXAMPLES
HOUSE OF MOVI
LW PLUGIN iNSTALL
VIEWPOINT-INFO
PROPACK STE UP (28.1 Mo)
READ ME
poser pro pack and poser4.0.3 are in english
thanks
pink999 ( ) posted Thu, 06 March 2003 at 4:45 AM
Maybe try cancelling when the install looks for poser install and you should be able to assign it manually then...
casamerica ( ) posted Thu, 06 March 2003 at 7:41 AM
Ah, I had the same thing happen when I first installed ProPack. Do as pink999 states - locate the Poser.exe file manually. That is what I had to do also. I have no idea why the PP could not find it, but since installation I have very few burps with ProPack. Take care, be well, keep flying. casamerica
