Wed, Feb 26, 4:06 AM CST
Subject: Selecting problems....again
maga ( ) posted Tue, 16 May 2000 at 6:31 AM · edited Wed, 26 February 2025 at 4:04 AM
I keep on having selection problems. I explain. I am creating some flat squares, and on each of them I have to put an image. I ctrl-D the object, click on the M and select the image I want to load. I load it and when I check the first square, it has automatically changed texture. tried to ctrl clik the object and all other triks, but they don't work. So here I am asking you if there is a chance to re-set the original settings of Bryce, seen that no other thing work. For your information, the only solution I found is to save every single object in the "create" box. But is such a loss of time! Thanks in advance for your help
Zottel1 ( ) posted Tue, 16 May 2000 at 12:08 PM
Do you create a new Image or do you overwrite the old one? I mean: does a new Image appear in the "Image Library" in the place you open the Pics for your Material or does it just change?
maga ( ) posted Tue, 16 May 2000 at 2:09 PM
No, I overvrite the old one. Go in the material lab when i open the texture source editor. There I find the last image, go to load the new one and click the check mark. When I go back to the scene, also the 1st object I had textured with another picture changes and both have the 2nd image textured on them. Hope you understand, it's not easy to explain in a language that is not yours....thanxxxxxx
Ghostofmacbeth ( ) posted Tue, 16 May 2000 at 3:57 PM
I am not sure if this will help but it seems that you are replacing the texture. Here is what I would do: Create a square or use the little Leonardo picture. Load texture in one of the free blocks. New square or duplicate the one that you are using. Load in new texture in new block. Hope that helps .. Let me know what you native language is and maybe I can help there. Good luck
maga ( ) posted Tue, 16 May 2000 at 4:49 PM
Ghostofmacbeth, thanx for your reply. I am italian. And duplicate the square and apply a new texture is what I do, but they all change to the last used. Maybe there is an option to reset all default settings?
Ghostofmacbeth ( ) posted Tue, 16 May 2000 at 9:37 PM
I havent heard of it doing that unless it was a pre-patch Poser 3. That could only have one material loaded in at a time and caused a lot of problems for me. You might try creating a new object or picture plane each time and see if that will help. It should be possible to have many pictures all loaded in from past experince. Good luck Oh .. My Italian is very bad but I have seen a nifty program. It might not be perfect but it might help. Translation: Non lo ho sentito parlare che fa che a meno che fosse una pre-zona Poser 3. Quello ha potuto soltanto avere un materiale caricato dentro alla volta ed ha causato il a.lot dei problemi per me. Potreste provare a creare un nuovo aereo dell'immagine o dell'oggetto ogni volta e vedere se quello aiuter Dovrebbe essere possibile avere molte immagini interamente caricate dentro dal experince passato. Buoa fortuna Il mio italiano dell'OH. molto difettoso ma ho visto un programma nifty. Non potrebbe essere perfetto ma potrebbe aiutare.
maga ( ) posted Wed, 17 May 2000 at 2:44 AM
Ghost......eheheheh very funny this program!!!!!Don't worry about translating, I can understand....the problem is, sometimes, to make myself understood when there is something to explain...:))))) thanx a lot!
Ghostofmacbeth ( ) posted Wed, 17 May 2000 at 8:01 AM
Gotcha. Hope things work out for you and you do much better with your English than I do with my Italian. Well let's just say I can barely speak it even a tiny bit but I can understand you pretty well. Good luck again.
Ghostofmacbeth ( ) posted Wed, 17 May 2000 at 10:55 AM
Oh .. was the translation that bad? Just was wondering since I had thought about using it for something else ..
Zottel1 ( ) posted Wed, 17 May 2000 at 11:40 AM
Click in one of the free squares next to your already loaded Picture and a new Open Dialog box will open. Agree a new image, and now you can see both pics in there.I think that this would help.( I can offer German as alternative Language).
maga ( ) posted Mon, 22 May 2000 at 2:39 AM
I would like to thank everybody for help, expecially Zottel1. I did as you told me, and everything was solved!!! I always learn something good from you all
maga ( ) posted Mon, 22 May 2000 at 2:40 AM
I would like to thank everybody for help, expecially Zottel1. I did as you told me, and everything was solved!!! I always learn something good from you all. If you wish, you may see the results in my gallery, title "I Ching"
Zottel1 ( ) posted Mon, 22 May 2000 at 12:10 PM
No Problem, maga. Thatswhy we are all here. Zottel1
