Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 22 4:32 am)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Someone cleverer than I will give you a better answer, but I think it's something to do with your vertices. Are you using UVMapper? If you are put it through there, press "weld vertices" and you should get the textures back. Seems .obj's need a little more work before being imported into Poser. I know this to be true of Poser 4. Then again.. this could be completely wrong! VH
Models that I construct and export from Rhino3D (3ds and obj formats) don't seem to hold textures in Poser5. If I render them in Rhino3D or Anim8or, the texturing and lighting effects appear. However, in Poser5, the model appears black and is not affected by lighting or reflection settings. I'm sure it's a simple fix. Any ideas why?
