Thu, Nov 14, 12:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 10:48 am)
Subject: Newbie Has a question here.... Can you help me?
magestyk ( ) posted Sat, 08 March 2003 at 8:13 PM · edited Thu, 14 November 2024 at 12:17 PM
I was wondering is there anyway i can save a render from poser 4 and open it up on photoshop 7 like a layer? That way I dont have to use the lasso tool and cut around the model. Also What size do you recomend i save the image? Any other tips are welcome... Thanks for your time.
PhilC ( ) posted Sat, 08 March 2003 at 8:20 PM
If you save in TIF or PNG format the image will include an alpha channel that may be used as a mask.
Manikin Flesh ( ) posted Sat, 08 March 2003 at 8:31 PM
Just out of curiousity, are you bringing the image into photoshop to put another image behind it. If thats the case it would be easier to use whatever background you wanted to use and then import it into poser, which would still allow you to manipulate the model and you could change the background whenever you wanted. If I've completly misconstrued your purpose for doing this I apologize. If I haven't go to file, import, import backgound and your image will be behind the model. Bill
Poppi ( ) posted Sat, 08 March 2003 at 8:44 PM
if you save as psd, you can open from alpha channel....that should just have your model. best to put in your background as a seperate render. and, render your figure against a black background. keep the lighting the same, of course.
ladynimue ( ) posted Sun, 09 March 2003 at 9:52 AM
Hi magestyk7, Here is a step by step for getting your Poser people into Photoshop, In Poser: Click File Click Export Click Image (a Save As Window will open) In the Save As Box: Find the folder you wish your image file to be saved to In the File Name Box enter a name for your file In the "Save As Type Box": scroll down and click on Tiff (.*TIF) (or in the photoshop format as Poppi suggested) As a safety feature, Before you close out Poser, Save your Poser .pz3 file Do that by clicking on File Click Save As (a Save Document As Window will open) name your file and click save. That way you can always come back to the Poser file later if you need to make changes. Once you have saved your .pz3 file, Close Poser and Open Photoshop Open the file as you would any Image file Once in Photoshop do as PhilC suggested. To the above steps if you want to import your Poser figure into Photoshop for post work. If however, you are just wanting to create a background, follow Manikin Flesh' suggestions. Hope this helps :) ladynimue
melanie ( ) posted Sun, 09 March 2003 at 10:15 AM
If you render in a new window, which gives a better render IMHO, you can just use the File>Save function to save your image as a TIF or PNG without having to export it. Melanie
maclean ( ) posted Sun, 09 March 2003 at 10:58 AM
It depends on what type of background you have, but an easy way to do it is to use any solid color for the background, like white/gray/black, make the render in a separate window and save it. In photoshop, duplicate the background layer, then using the magic wand, click on the background color and press shift-delete. This will leave you with a separate layer with a transparent background. mac
queri ( ) posted Sun, 09 March 2003 at 12:18 PM
Mac, I find that often leaves a darn halo that takes forever to get rid of. Here's what I do. Import background pic into poser. Pose my scene, but render over black-- why? because too often the lights or something will make the background too darn pixelated to use. Save the render as a Tiff. Take into either PS or PSP. Go to Layer view, go to Channels, the last channel is Alpha, select, hit CTRL. Go to Layers and add new Layer from copy. Your second layer is up there with a good alpha mask. Select your background picture, copy, select background on your render-- the one that isn't masked-- and paste. Your background will be behind your picture on a separate layer and you can adjust and post from there. I try to keep at least one clean layer copy in case I screw up mightily so I use a lot of layers. [The above was described step by step for PS but PSP is similar] Emily
boulder ( ) posted Sun, 09 March 2003 at 6:08 PM
Hmmm interesting the different ways you all do this. The way I use is to save as an uncompressed PSD format. Then use the alpha channel. I would never import a backdrop in to Poser. A lot of quality is lost. If I really need a backdrop in Poser I use a square prop and put the bkground on that
magestyk ( ) posted Sun, 09 March 2003 at 6:30 PM
Danm, That's alot of Techniques you Guys and Gals got there. Thanks every 1 for your tips. I had to print the whole thing out cause alot of the stuff you guys talked about i'm just getting the hang of it.
Poppi ( ) posted Sun, 09 March 2003 at 6:43 PM
hey, while we are on this subject...how do i get a psd that will save an alpha channel from a bryce render? anyone know? i tried my darnedest to figure it out on the last render i posted, but, to no avail. if someone has a clue fairy to send me, i would really appreciate it. :*)
tasquah ( ) posted Mon, 10 March 2003 at 12:22 AM
Poppi : I know its a do-able thing because i have seen people talking about it here . I believe you use the "export image" option and you can save it as a Tiff or a PSD .
