If you want to use Winzip, I attached a little tutorial I made for a friend to this post. Just follow the instructions in red, and obviously point Winzip to your Poser 5 folder instead of Poser 4. My tutorial assumes that the person who put together the Zip file included the path info (RuntimeGeometries etc.) so Winzip knows where to put the files.
They do go into different folders. If you have a good ZIP file, they will go in the right places when you check the USE FOLDER NAMES BOX. You can tell if it is a good ZIP by looking for PATH information in the main WINZIP Screen. There are a bunch of tutorials about this sort of thing, including in this very forum a few messages away. Personally, I recommend Ploader from Free Stuff, or PInstall from the Marketplace if you are going to be doing a lot installing. These programs will read the files involved and install them in the correct places. good luck, e.d.
Please is there someone that can tell me how to install poser models. I can't seem to get it right. I am using poser 5. Thanks
