Mon, Feb 3, 1:40 PM CST
Subject: Poser 5 Hair weirdness
odeathoflife ( ) posted Tue, 11 March 2003 at 10:44 PM · edited Mon, 03 February 2025 at 1:32 PM
Hey Folks what am I doing wrong? I am making an animation and when I do calculations for the hair and in the room help it says to use collisions to stop the hair from interescting with pther things in the scene...well you see the results, it is like the hair is also colliding with itself...or am I just doing someothing wrong.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
CrystalDragon ( ) posted Tue, 11 March 2003 at 11:28 PM
That's because the hair IS colliding with itself (at least, that's what I've allways assumed)... You're not at fault, this is a long standing bug in P5. Here's the two main threads I've seen on this:
http://www.renderosity.com/messages.ez?Form.ShowMessage=977278
and here:
Good Luck!
~DM
odeathoflife ( ) posted Tue, 11 March 2003 at 11:38 PM
thats both the same link but I noticed something that I didn't do ( I didn't turn on collisons...errr ahem scuse me LOL) I will also crank up the gravity a tonne and see what happens.
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
leather-guy ( ) posted Tue, 11 March 2003 at 11:47 PM
There's another possible factor - the helmet so close on the scalp may be forcing many more deformations and collisions than normal. Have you considered re-mapping the hair "field" (can't think of another term just now), so it's just a fringe around where the helmet doesn't cover? It may not be part of the problem at all, but it seems like P5'd have to make a ton of unnecessary calculations for hair that doesn't even show. Hope this was relevant, or even helpful...
odeathoflife ( ) posted Tue, 11 March 2003 at 11:50 PM
oh there is no hair under the helmet LOL he is as bald as a baby's bottom on top, I have been trying this with the helmet off as well with the same resuls
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
saxon ( ) posted Wed, 12 March 2003 at 3:14 AM
If I remember correctly I removed this from the original thread in a fit of peek.
saxon ( ) posted Wed, 12 March 2003 at 3:43 AM
Odeathoflife, you've provided some excellent freebies, thankyou... I've some thoughts that might help. Try removing the head from the objects to collide with, I know it seems odd but try it. Next, remove some of the hair closest to the helmet so the the hair that needs to move doesn't touch it at all, remove the helmet from the list of objects to collide with. Next, make a new row of hair around the helmet, much shorter and pulled down hard, don't animate this row but allow it to show through, it'll probably take a little while to get right. Next shorten the longer hair that hangs down below the helmet and pull this back. Finally, remember that an animation is not a still and relies much more on artifice to achieve realism but you can get away with much more!
cruzan ( ) posted Wed, 12 March 2003 at 10:27 AM
Ohhh, SAXON, that is the most beautiful usage of the Hair that I have seen! Wonderful animation and thanx for the tip of removing the Head as a collision Item - that may have just fixed one of my problems!
GraphicFoxx ( ) posted Wed, 12 March 2003 at 11:10 AM
How can you remove the head as a collision item? P5 hair doesn't have 'collide with' like the cloth room does.
cruzan ( ) posted Wed, 12 March 2003 at 12:13 PM
it does have do collisions (to right of dynamic controls) am currently awaiting Calculate dynamics to finish to see if head will be listed somewhere......
odeathoflife ( ) posted Wed, 12 March 2003 at 1:02 PM
collisions are in the properties of the object FYI
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
saxon ( ) posted Wed, 12 March 2003 at 2:37 PM
Sorry, I should have made that clearer! ODOL is absolutely right. You need to view the original thread to see how it's done. Thanks for the kind words cruzan.
odeathoflife ( ) posted Wed, 12 March 2003 at 3:01 PM
For anyone that cares here is teh almost completed Sturm Brightblade, that I am working on (I need a good chainmail texture, and have to do textures for the armour) but all the modeling is done (cept his sword that is)I am going to make all the DragonLance 'classic' characters and make a movie of the 1st module.
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
odeathoflife ( ) posted Wed, 12 March 2003 at 3:03 PM
and for those not in the know here is a pic frpm dragonlance
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
