Fri, Sep 20, 10:46 AM CDT
Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Subject: Dowloaded Bryce .odp files fail format check
johnkramar ( ) posted Wed, 12 March 2003 at 12:46 PM · edited Fri, 20 September 2024 at 10:30 AM
Hi, I'm running Bryce 5 on a 400 MHZ PowerMac running OS-X 10.2.4 and I can't upload .obp files that I download from Renderosity. If I have format check on Bryce won't read the file and if format check is off there is an error message "An unexpected error has occured (invalid format)" at the end of reading the file. Is there some kind of modification that I need to make to the file or is there is translation program ala the oser MacConverter? Cheers,
Aldaron ( ) posted Wed, 12 March 2003 at 1:23 PM
Where are you trying to import it? You can't use the file/import object. You must click the little triangle next to the word Create in the top pallette, then select a category to place it in then click import. Once in the library select it and click the check mark to place it in your scene.
AgentSmith ( ) posted Wed, 12 March 2003 at 3:44 PM
Just to get rid of some of the simpler things first... Did you unzip, unrar, unsit, the .obp? It was most likely archived/compressed somehow. (Just want to make sure)
johnkramar ( ) posted Thu, 13 March 2003 at 6:59 AM
Thanks, I was trying to import using File/Import Object Cheers
