Tue, Jan 21, 5:32 PM CST
Forum Moderators: Staff
Subject: bringing in a character Parameter dials
dmayberry ( ) posted Fri, 19 May 2000 at 8:20 PM · edited Wed, 08 January 2025 at 4:17 AM
Does anyone know how to delete or not have certain parameter dials? Such as x rotate or y translate etc. Iknow about setting limits on dials.However some models I'm working on only need like 1 rotate doesn't need any thing else.
Cage ( ) posted Fri, 19 May 2000 at 8:35 PM
You can turn a given dial on or off by editing the cr2 in a text editor. The "on" and "off" position for each dial is represented by a one or zero in the channels section for that parameter. Unfortunately I haven't done this in a while and I don't remember the details as to which line you should look for....
ScottA ( ) posted Sat, 20 May 2000 at 8:36 AM
In the .CR2 file. You'll need to first search for the body part name you want to edit the dials for. Once you've found it. There is a line called "Channels" a little ways down the file. There are several names of dials,translate,rot,offset, ect. these are all types of dials. a few lines of text below each of those names you'll see a word called "hidden". There will be either a 0 or a 1 directly after it. 1=dial visible 0=dial invisible ScottA
dmayberry ( ) posted Sat, 20 May 2000 at 4:03 PM
Thank you kindly! I knew there was a way just couldn't recall hearing about it
