Wed, Feb 5, 5:11 AM CST
Subject: exporting obj
mythicnexus ( ) posted Sat, 22 March 2003 at 8:57 AM ยท edited Tue, 04 February 2025 at 2:11 PM
Is it possible to export victoria 2 head without the teeth and the tongue? Because when i import her head in bodypaint 3d and uvmap her, the teeth and the tongue show up. can someone tell me how to get rid of the teeth and tongue?
VI_Knight ( ) posted Sat, 22 March 2003 at 9:20 AM
I don't think it is possible but you can get UVMapper (Free version here in freestuff) and load the exported head obj and remove the teeth and tongue and save to a diffrent obj if yo uwant to keep the orignal that you just exported. Then import that new obj into bodypaint 3D
mythicnexus ( ) posted Sat, 22 March 2003 at 10:01 AM
how do you remove them in uvmapper?
VI_Knight ( ) posted Sat, 22 March 2003 at 10:32 AM
Once it is imported select/select by/Material or CTRL-M. Then a list of the areas will po up. Just shift select Tongue and Teeth. This will highlight them. For some reason it doesn't let you delete them so you will have to hide them. press the [ key to hide them.
Dizzie ( ) posted Sat, 22 March 2003 at 11:21 AM
Thank you so much for that explanation...I was asking about this very thing a few weeks ago and everyone said you couldn't delete a part with the free version of UVMapper, no one bothered to say you could hide the part for the same effect....
VI_Knight ( ) posted Sat, 22 March 2003 at 12:46 PM
The one part I am not certain about is after it is hidden if it remains hidden after the export. Someone with the Free version would have to clarify this. I am using the pro version so I am not sure how that would work.
Netherworks ( ) posted Sat, 22 March 2003 at 1:51 PM
Hmm... Try this... select those materials you don't want and assign a new group to them. Export the mesh as a different name. Import into Poser. select the head. go into the Group editor and with the head selected "create new Prop" and give it a unique name. Export that head and it should go without the materials you don't want (tongue, teeth).
