Mon, Jan 27, 7:16 AM CST
Subject: Annoying bumps!
FrenchKiss ( ) posted Sat, 22 March 2003 at 7:08 AM ยท edited Sun, 26 January 2025 at 4:31 PM
Hi all! I am trying to create some new textures and bump maps for a castle wall I'm creating. I can't figure out how to make the textures straight on a cylinder. When I add a mapped bump the texture always comes out diagonal! What am I doing wrong? TIA Linda
gebe ( ) posted Sat, 22 March 2003 at 9:28 AM
Try to select Cylindrical for the mapping. If this doen't work and if the tower were created outside Vue, create an UV map for it (with UVmapper. Guitta
FrenchKiss ( ) posted Sat, 22 March 2003 at 11:38 AM
Unfortunately I've tried all the bump mapping possibilities and none of them work. The tower was entirely created in Vue too. How exasperating! Oh well. Thanks for your time!
gebe ( ) posted Sat, 22 March 2003 at 11:41 AM
The material you show in your material window, seems diagonal too. So it comes out diagonal. If you like, I can try if you send it to me at gebe@renderosity.com
FrenchKiss ( ) posted Sat, 22 March 2003 at 12:17 PM
I was just about to send the image to you, when I realized it IS diagonal! Well, part of it is and that's what's showing up in the bumps. I just didn't see it. Guess I'd better try another one (and get some new glasses). Thanks so much!
sittingblue ( ) posted Sat, 22 March 2003 at 2:55 PM
You may want to try this: Create a 'new' texture from scratch. By this I mean, in Vue 4.12, reset the material (right-click on material preview and choose reset material from the pop-up), and then set the various material channels. This fixed a problem I had once (with a brick texture oddly enough).
Charles
Charles
FrenchKiss ( ) posted Sat, 22 March 2003 at 3:50 PM
Hummm, interesting. I'll see if it works! Thanks Charles!
gebe ( ) posted Sun, 23 March 2003 at 3:26 AM
Frenchkiss, before you do complicated things, just try to rotate your existing texture a bit. Don't forget then to rotate the bump too. :-)Guitta
FrenchKiss ( ) posted Sun, 23 March 2003 at 9:06 AM
Oh cool! I never saw that! It should help for mapping textures on planes too. Thanks Guitta!
Flycatcher ( ) posted Sun, 06 April 2003 at 9:05 AM
Thanks for that last one Guitta! It never ceases to amaze how one can use software like this for months and have a blind spot for some less frequently used items on the menu. I had totally forgotted these rotation and twist features existed. This FAQ section which I am slowly working my way through is proving very helpful and interesting.
