Sun, Dec 22, 4:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Eye joint setup.
nerd ( ) posted Sun, 21 May 2000 at 9:35 PM ยท edited Sun, 22 December 2024 at 11:18 AM
Forum Moderator
I saw a tutorial or post once covering the "right" way to setup eyes. It involved editing the CR2 and removing a few channels. Anybody remember where the tutorial is or which channels to delete. Nerd
wyrwulf ( ) posted Sun, 21 May 2000 at 9:50 PM
It was here in one of the forums. Might have been ScottA.
nerd ( ) posted Sun, 21 May 2000 at 10:26 PM
Forum Moderator
Found it! And yup it was ScottA. In the Charactor Creator Forum. Here
wyrwulf ( ) posted Sun, 21 May 2000 at 10:41 PM
Thanks for finding it. That was one I didn't save.
nerd ( ) posted Mon, 22 May 2000 at 2:07 AM
Forum Moderator
Woops, there's a little more to it... You also have to edit the Head section. Remove every channel that refers to the eyes. I think there are six channels. (left and right; X, Y and Z) Just use a text editor that can search for part of a word and find all the refrences to "eye" in the head section. If the channel has "eye" in it it needs to go. I figured this out by comparing the new figure file to the P4NF CR2. If Im off course, somebody let me know. nerd
ScottA ( ) posted Mon, 22 May 2000 at 10:56 AM
You are right Nerd. I should have stated that more clearly. The fact is. When ever you remove the twist and or smoothing lines to accomplish this bending without warping things around it trick. You need to edit the FIRST instance of that body part as you scroll down through the .cr2 file. I always use the "find" function in a text editor to find them. And I forget to tell people that a lot of the time. The body part you are editing to do this. May be listed under another body part name first. Did I confuse everyone? ScottA
nerd ( ) posted Tue, 23 May 2000 at 12:24 AM
Forum Moderator
OK, having to run all over the place once was enough, I made a tutorial covering this. It will be posted in the tutorials section or you can find it at my web site, here: Nerds Tutorials
