Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 2:04 am)
I had the same problem, but found a workaround. In the PC environment, some uploaders send the OBJ as RSR file. I converted the RSR's from Bushi using the rsr2obj application (I think it can be found in the utilities section). After converting and replacing Bushi's RSR's with the OBJ's, all went well HTH Siegbert
Hi again, maga The rsr2obj by Anthony Appleyard (I think that is his name) has made quite a few very usefull modules. It can be found in the utility section of the Poser Free Stuff. The RSR's in some of Bushis's creation are really Obj's. The conversion of the RSR's to OBJ's was successfull on my PC. P4Eyes and the Wings. Siegbert
One more important item, maga. I have a well organised Poser Directory, and I have to use an editor to change many of the great downloads from Renderosity to the directories I have on my system. You must open some of the text editable files (CR2's PZ3's etc...) and check if you have required folders; if not change the folder names or create new ones. HTH Siegbert.
I just downloaded these eyes, but I have troubles in using them. Poser says obj. file is missing, but in the downloaded file there is no obj. file. Can anybody help? I had the same problem with bushi's wings too
