Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 03 7:37 pm)
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=18292
****This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Introducing Masquerade, a hi-resolution photo real texture/character package for Vicky 3 by Visual Silence.You MUST own Victoria 3 Base and both the head and body morph packages to properly use this package. These items can be purchased through DAZ3d.com
The MOR poses will inject the correct Morph targets and set the values to set up your Anna character. However, in order to utilize the expressions for Anna, you will need to use the injection pose located in the following directory, Poses/!V3 Expressions INJ.
To install this package simply locate your Poser 4 folder and unzip, the files are already set to create and load into the proper folders.
In this package you will find:
1 Mor pose that will inject all required morphs and create the Anna character
1 Mor pose that will only inject and set the head morphs for Anna
1 Mat poses to apply the default Anna textures
7 Mat poses to apply the extra Make-up, change of eye colors and Masked faces for Anna
1 Anna Body texture map (3000x4000)
8 Head texture maps for Anna (4000x2719)
1 Teeth texture map (900x900)
12 Eye texture maps (1000x1000)
1 Transparency map (2000x2000)
Renders created with Global Lighting from DAZ, the only postwork is some sharpening after resizing the renders to compose together.
