Tue, Feb 18, 5:29 AM CST
Subject: distribution of material map?
treemont ( ) posted Thu, 27 March 2003 at 2:01 PM · edited Tue, 18 February 2025 at 5:16 AM
I read in vue forum about this option, sounds cool, how can i do it in bryce?
Hepcatbrandon ( ) posted Thu, 27 March 2003 at 4:44 PM
could you elaborate?
treemont ( ) posted Thu, 27 March 2003 at 5:22 PM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=194&PageAction=View&Page=5
it is when you use 2 textures and a map so that one texture could be seen coming through the other in some spots...
well.. I read it in a really cool tutorial from thomaskrahn
here's the link with an example..
Hepcatbrandon ( ) posted Thu, 27 March 2003 at 5:34 PM
that looks like a useful effect. I'm pretty sure there is a way to do this using an alpha channel, in the same way that people get an altitude blend between materials on a terrain. I'll check but somebody else will know how to do it
GROINGRINDER ( ) posted Thu, 27 March 2003 at 5:41 PM
I believe this could be done in Bryce by duplication of the obj parts that you want to apply this to and making 2 sets of tex maps then use the transparency maps to balance between them.
Aldaron ( ) posted Thu, 27 March 2003 at 6:22 PM
Yes it can be done with an ABC blend. In the diffuse color section of the material lab (and probably in the ambience too depending on how you want it to look) place a marble in channels A, B, and C. In the A channel put the texture you want the overall wall to be, B channel will be the brick texture and C channel will only use the alpha part of the texture. Where the aplha is white channel A will show, where it's black B will show, gray will be a mix.
Aldaron ( ) posted Thu, 27 March 2003 at 6:24 PM
Oh and you'll probably want marbles in the bump values too (AB&C). If you need a screenshot of the material lab let me know.
treemont ( ) posted Thu, 27 March 2003 at 6:28 PM
this is cool, it will get me started experimenting :) yes screenshot would be nice! thanks Aldaron!
Aldaron ( ) posted Thu, 27 March 2003 at 6:59 PM
Ok here it is
treemont ( ) posted Fri, 28 March 2003 at 12:22 AM
perfect, thank you so much :)
garcia ( ) posted Fri, 28 March 2003 at 1:33 AM
Attached Link: http://www.designbydeanna.net/bryce/spraytutorial.html
this might also help..
Erlik ( ) posted Fri, 28 March 2003 at 5:30 AM
http://www.castironflamingo.com/tutorial/imagemap/index3.html http://o.ffrench.free.fr/tutorials/mixing/
-- erlik
