Thu, Feb 6, 5:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Talking Models With Lip Synchronization?
Adenosine ( ) posted Sat, 29 March 2003 at 8:49 AM ยท edited Sat, 10 August 2024 at 2:22 AM
Hello there again! Is it possible to make our models in Poser 5 actually "TALK"? I'm planning to make my model "speak" my pre-recorded audio file... Thanks again in advance people... I'm sure this one is gonna be interesting for us all...=)
VI_Knight ( ) posted Sat, 29 March 2003 at 9:02 AM
Attached Link: http://www.daz3d.com
Check out the program MIMIC at Daz
raven ( ) posted Sat, 29 March 2003 at 10:12 AM
Attached Link: http://www.fantasy3d.com/phon/posersync.html
Here is a link to an online .pz2 generator, that uses typed in words as opposed to Mimic's sound file use.
raven ( ) posted Sat, 29 March 2003 at 10:13 AM
Oooops, .pz2 should read .fc2 :)
Adenosine ( ) posted Sat, 29 March 2003 at 10:33 AM
Thanks for the links...... but....... about the FC2... how do I use it? Can someone please explain how it should be used? Thanks... I'm quite new to this fc thing, as well as the cr files that I've been seeing quite often...
raven ( ) posted Sat, 29 March 2003 at 12:39 PM
Attached Link: http://market.renderosity.com/~pzr/extensions.html
It goes in your Poser 4/Runtime/Libraries/face/**** folder (where **** folder is whatever you want to call it), and you apply it to your figure like a pose. It then loads the animation frames for the text/speech. It may ask if you would like to add frames, it may not. You would have to import the sound file separately. Mimic makes it a lot easier as it imports your sound file along with the animation frames. If you want to do a lot of lip-syncing, I would recommend Mimic, I have it and it is easy to use and gives good results. This link should explain all the extensions and where they normally go for you :)
Adenosine ( ) posted Sun, 30 March 2003 at 5:34 AM
Thanks a lot... problem solved! I'm able to make my characters talk now.... hehe... this sure is a big help in my mini-show ehehehhe...
