Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 1:47 am)
Is it strange by the addition of some weird characters at the start and then normal thereafter? I've seen that with files that started on the Mac, and usually the fix is to delete about a line of junk before the first { (that's a curly brace if your screen is as hard to read as mine) and it will then work.
Sounds like the mac files got used for the windows version. Worth trying maconverter to see (I don't have it, so I can't say) Mac files do have the rsr (thumbnail) in front of the regular cr2 stuff...so that sounds likely. Also, macfiles use a different return character sequence, which makes them look awful in notepad (wordpad should show the returns properly, however) eric
I just purchased Underworld Relms.. Well I doesn't work! I get an error and cannot use the product.
I am very upset right now and would like to know how you can release a product that doesn't work. I feel that your products are not what they used to be and after this I think I will not buy anymore till things get fixed! It seems to me that every time I buy a Daz product I have to wait for an update... For instance when I bought Anime Doll I had to wait till it was fixed, also when I bought V3xpression magic, had to wait for updat to get it to work, and I could go one with a few other products.
I am about ready to look for an alternitive source for my poser
Poserverse The New Home
for NYGUY's Freebies
Tried converting it using dodger's site converter, didn't work. I also tried editing it myself... I found some major problems with the syntax and gave up after the first file.
I am really glad I saw this thread, as I was about to purchase Underworld Realms. It's gorgeous, and I still want to get it after DAZ has it fixed. This is a little OT, but I have to ask (sorry). Is the articulated skeleton required to use this product? Or is Underworld Realms a standalone figure? (I realize it is kind of hard to answer the question right now, since no one seems to be able to get UR working, but thought I would toss out my question anyway just in case someone could answer.) I really hope the problem is resolved soon for all purchasers! Kimberly
Well I don't know if the articulated skeleton is required, there was nothing on the site about it.
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=1168262
The first day that the product was offered for sale at Daz, there was a notation on it that the articulated skeleton (Daz Skeleton or Skeleton AV) was required in order to use it. (Rather pricey item that is, too!) The next day, the notation was gone. I have no idea what was up with that, but here is a link to the Product Showcase in which it is discussed. I'm a bit confused as to what, if anything, is required in order to make this product function. KimberlyWell I am happy with the results I got from tech support from Daz. I had already used my 3 downloads, thought I had a corrupted file. They had reset my downloads so I can redownload it. I agree this should have been caught before it was released, but I have talked to other people who had bought it and they said it opened with no problems. I had tried to manually edit it to work but found some major flaws in the syntax that I couldn't fix, like words running together where there should have been a space. Also some of the synax look strange. I am going to wait before downloading anything from Daz again till I hear that it works... Even the freebees have problems some times.
Sometimes if you open a Mac text file (and a CR2 is just a text file) in a Windows text editor the line breaks will be invisible and it will look as if the end of one line runs into the beginning of the next. This is because the Mac uses one character (10 or 13 - can't remember which) to mark line breaks where the PC uses both 10 and 13 (line feed and carriage return respectively). It doesn't confuse Poser, though it does make it harder to spot errors.
Okay. I can't get any of the figures of the Underworld Realms at Daz3D to work. They say they aren't a valid Poser file. Anyone else having this problem? And does anyone know how to fix it? :/ I have Poser 4 with Windows XP.
