Well as lelionx suggeted you can download the Morph Manager in the Poser freestuff section, but this only works if the figures share the same Geometry file for example, you can't copy Victoria's morphs to the P4 woman, but you can copy Victoria's morphs to Reika or Tenten.
Ask me a question, and I'll give you an answer.
Mind you, these are only the full-body morph control dials. If you want to delete the actual morph deltas themselves, you'll have to identify and manually delete each body-part morph linked to that control dial.
As far as copying goes, Morph Manager can copy the individual body-part morphs that make up the full-body morph, but not the full-body morph control dials. You'll have to cut-and-paste the control-dial info into the second figure's CR2 using a text editor.
I loaded a .pz2 and then my .pz3. The Body morphs showed, but then when I copied them over to an M2 Shell.cr2(An M2 .cr2 with all of the MTs deleted from it.), and opened that in Poser 4, the Body MTs showed, with the value they were transfered with, I then saw they didn't reshape the figure at all, why?
How do I get rid of unused Full-Body-Morphs in cr2 files?
The regular way with Morphmanager and the other within P5 does't work.
How can I copy them to other cr2 files?
Anybody knows?
