Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 11:00 pm)
DivX offers good quality and compression ratios.
If you have sufficient room on your hard drive, however, I recommend rendering the animation as an uncompressed AVI, or as an image sequence which can be assembled into an AVI later. Save the compression process for the last step, after you've finished editing and postworking the raw video.
A proper DVD requires MPEG-2 compression in order to work on most set-top players.
Attached Link: http://math.berkeley.edu/~benrg/huffyuv.html
If you want quality, I'd suggest huffyuv. ~DMIf i'm rendering something relatively small, I usually render as uncompressed; If i'm doing something truly monstrous, I use cinepac with 0% compression; it's about the only codec I've been able to get poser to work with without screwing up in some way. seems pretty lossless, also (I know it's not, but there is no VISIBLY apparent loss).
I make a DVD movie with Poser 5. What is the best AVI codec? I download DV codec, but appear a Poser message error and this codec not work. I need help Tanks.
