Tue, Jan 28, 2:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 11:56 pm)
Subject: Facial problems
fnwolf ( ) posted Wed, 24 May 2000 at 9:50 AM ยท edited Tue, 14 January 2025 at 3:58 AM
Hi. I'm trying to animate a face close-up. After I set it up, then play it back, the face contorts far past where I set it. Am I doing something wrong, is this common, is there any way around it? Thanks, Jack
bloodsong ( ) posted Wed, 24 May 2000 at 9:55 AM
heya; you're running into the animation spline problem. in the animation palette, look for the four buttons with lines, like a curvy s line, and a jaggy triangle line... select your keyframes and press the jaggy triangle line. that makes the segments linear (not spline) animated. the splines tend to snake through keyframes, and go past your most extreme pose/setting before they turn and go towards the next keyframe. er, is that making any sense?? :)
jeffheater ( ) posted Thu, 25 May 2000 at 12:49 AM
I usally just lock the parameter dials, for instance: double click on right eye blink, reset min. 0, max 1,that's always cleaned things up for me. Jeff
