Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
heya; you're running into the animation spline problem. in the animation palette, look for the four buttons with lines, like a curvy s line, and a jaggy triangle line... select your keyframes and press the jaggy triangle line. that makes the segments linear (not spline) animated. the splines tend to snake through keyframes, and go past your most extreme pose/setting before they turn and go towards the next keyframe. er, is that making any sense?? :)
Hi. I'm trying to animate a face close-up. After I set it up, then play it back, the face contorts far past where I set it. Am I doing something wrong, is this common, is there any way around it? Thanks, Jack
