Fri, Nov 15, 1:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: looking for a easy way to adjust AV skeletton inside Mike 2.0
kyo ( ) posted Fri, 04 April 2003 at 1:39 AM ยท edited Thu, 14 November 2024 at 10:17 PM
Hi, i just want to make a trans pic : michael 2.0. with a skeleton inside (fit to body) but i have only : -ZYgote AV Skeletton and normal male and female skeletton in poser 4 librarie how to adjust this to have the same proportions with michael 2.0. ??
SamTherapy ( ) posted Fri, 04 April 2003 at 10:30 AM
I really don't think there is an easy way. For one thing, the joint parameters are different, so even if you scale the thing to fit inside, you will have a lot of fun trying to get the two of them moving in unison.
kyo ( ) posted Fri, 04 April 2003 at 11:16 AM
well, just a travellin cam around body to see through the skin , no motion body... so i have to adjust joint parameters , But is there some script to automatize this ???
hauksdottir ( ) posted Fri, 04 April 2003 at 7:20 PM
If you have Poser ProPack or Poser 5, there is a SetUp Room where you can move the"bones" around to fit, or copy "bones" from one figure to another, and then tweak. (These bones are the interior framework which tell a mesh where to bend and how far.) I believe that the default skeleton that comes with Poser was based upon the Poser 2 male (ages and ages ago). I'm not sure about the proportions and height for the AV skeleton, but it is pretty old as well. The skeletons really do need an upgrade to go with the Millenium figures, but the return on investment probably isn't there. How many clothes does a skeleton have in her wardrobe? [Actually, glance over at Lucy in the closet... she has a decent selection of coats... hmmm... the chattering of teeth must be an old habit.] Even if your figure isn't animated, you'll want to pose him so that he is standing naturally. If you can get the bones aligned, then you can also copy the pose and slap that onto the skeleton as well. Carolly
