Sat, Jan 11, 7:57 PM CST
Subject: Pose library too large
amlaborde ( ) posted Wed, 02 April 2003 at 1:05 PM · edited Fri, 10 January 2025 at 4:01 PM
I know this has been discussed before but I want to make sure I understood right. My pose library is so huge that I cannot even get to anything near the bottom. LOL If I were to move some of the mat files and such to a different library such as camera, would these still work as pose files? And is the camera library the only other one I could use?
Marque ( ) posted Wed, 02 April 2003 at 1:09 PM
I believe you can use the hands library. You have to change the extension to cm2 for the camera library. Marque
SamTherapy ( ) posted Wed, 02 April 2003 at 1:15 PM
Yep, you can use the hands library, but it has some weirdness when you load a pose and select the left hand, IIRC. On the other hand (sorry) you could always buy PBooost.
amlaborde ( ) posted Wed, 02 April 2003 at 1:24 PM
If I do use the camera and rename the files cm2 They will still work as poses even though poser is reading the files as cameras? Hmmm. I think I will pass on the hands library. I have a hard enough time with poses without any other hangups. I have heard of Pboost what exactly does it do? And is it in the Marketplace?
queri ( ) posted Wed, 02 April 2003 at 1:31 PM
I have both Camera and Hands filled -- you just pick Right hand all the time. P3DO Has a batch renamer that I used for this. But I have so big a Runtime it occassionally poops out. This is the one thing I don't miss with Poser 5. Emily
Marque ( ) posted Wed, 02 April 2003 at 1:35 PM
I hear you there Emily. I finally got pboost to run but it's haphazard at times so I'm thinking of moving to P5 for everything. Marque
Eowyn ( ) posted Wed, 02 April 2003 at 1:54 PM
I've put all clothing MAT files into Face because I rarely use ready faces or expressions :) I tried putting things in the Hands library as well but I found it utterly annoying that I always had to choose one of the hands :P
leather-guy ( ) posted Wed, 02 April 2003 at 3:22 PM
You can use Cameras, Hands, and Faces for MAT files. They'll work in Lights, also, but they turn off any existing lights in the scene as a rude side effect. I think this is the fourth time this has come up since Sunday. Must be an epidemic.....
Tomsde ( ) posted Wed, 02 April 2003 at 3:23 PM
What version of Poser do you have? Poser 5 makes it possible to create alternative libraries outside of Poser in any location that you want. Most of my stuff is in the PP 4 library which I can easily access from P5. When that if full I will start storing stuff in other locations, if I ever get to the point where I want to uninstall Pro Pack I can copy the entire runtime library to another directory and do away with the program. Right now, though, until all the P5 bugs are worked out I am keeping it on my system.
SamTherapy ( ) posted Wed, 02 April 2003 at 3:34 PM
PBooost isn't haphazard at all if you set it up correctly and make sure all your texture paths are squeaky clean. Seriously, I wouldn't be without it now.
amlaborde ( ) posted Wed, 02 April 2003 at 3:47 PM
Thanks a bunch, I will try out PBoost I think. Knowing my luck, I would rename something wrong and screw it all up. LOL! I cant get PBoost until hubby gets paid but maybe until then, I will try moving a few files at a time to say the camera library to see how that works as well. :) Oh and btw I have Poser 4 (Someone asked up in the thread.) I have heard too many discouraging things about the bugs in 5 right now, so I will wait until it is all straightened out.
SamTherapy ( ) posted Wed, 02 April 2003 at 4:09 PM
Advice before buying/installing/using PBooost. Go to Freestuff and get the Compatibility test util and Correct Reference. Run the Compatibility test first, then Correct Reference. Then, run the Compatibility test again. That should tell you how PBooost will run on your system and whether or not it's worth buying. Hogwarden (the author) has some useful tutorials and tips at his site, too. The link is in the free utils.
FishNose ( ) posted Wed, 02 April 2003 at 4:17 PM
I have Pose full, just brought it down from 262 folders to 255 today (that's the max number it will handle without going nuts). I have all clothing MATs in Camera and all character and hair tex MATs in Hands. Okay, the 'pick a hand, any hand' is a drag, but it works fine. EXCEPT for one thing: if you have a MOR pose that controls Body dials (can be done if you construct the pose file manually), the Body dials will not be changed if the pose is run from Hands. If you move the pose back to Pose, it works OK! Ths is the only anomaly I know of so far. So my Hands is nearly full and Camera is filling up fast.... .... Next will be Faces I guess. I'm stuck with P4 for a while yet. I won't be buying P5 until the price here in Sweden stops being double that in the US. No way. Hell, I can other apps here for the same money as in the US, why should I let the Scandinavian Poser distributor get rich? :] Fish
Marque ( ) posted Wed, 02 April 2003 at 4:41 PM
Sam I would get all my textures "squeaky clean" if I could, but I keep getting memory errors when I use the program that is supposed to do it. Please don't act like I'm an idiot because the program doesn't work on my system for some reason. And I'm not the only one who gets those errors. Marque
SamTherapy ( ) posted Wed, 02 April 2003 at 4:49 PM
I'm not acting like you're an idiot. I suggest you contact the program author if you're getting errors. If you get the file lock problem when using PBooost, use the Deep File Editor to reset the texture paths. It can be tedious, but it does the job.
Mariamus ( ) posted Wed, 02 April 2003 at 5:06 PM
hehe.. someone should just make a huge package of all the files you need to run Pboost.. the compatibility tester, correct reference, deep file editor.. LOL :) Mariamus
Marque ( ) posted Wed, 02 April 2003 at 5:58 PM
He sent me the beta of the new one, which I'm not using because it locked up my system, and since then I have not heard from him. Marque
PeterWahoo ( ) posted Wed, 02 April 2003 at 7:43 PM
I think you are using Deep File Editor, a utility inside PBooost, rather than CorrectReference. (That is a separate program.) Get CorrectReference, and use it.
amlaborde ( ) posted Wed, 02 April 2003 at 9:18 PM
Ok ya'll are scaring me with all of these extra programs. LOL :) Umm let me read through these posts and I will try the compatibility tester thingie first. So far though, I have moved a few mat file folders to camera and so far no problem.
LilWolff ( ) posted Wed, 02 April 2003 at 10:24 PM
I did not know you could use the hands and face folder for mat files. I guess you have to change it to that extension like you did for the camera? Thanks! My folders now are getting very filled up.
lmckenzie ( ) posted Thu, 03 April 2003 at 3:04 AM
I suppose you could set up some batch files to rename directories before starting Poser - sort of a poor man's way of doing what PBoost does when your system doesn't support switching while Poser is running. In your libraries folder, you'd have a batch file like "Fantasy.bat," that would be something like: rem ----------------- Fantasy.bat ----------------- ren pose "pose-old" ren "pose-fantasy" pose start /w ....Poser ren pose "pose-fantasy" ren "pose-old" pose exit rem ----------------- Fantasy.bat ----------------- As long as you don't mind not being able to switch from within Poser, you should be able to set as many of these as you like. With a little more work, you can combine them all in one bat file with a menu to select the configuration to run. Of course, this assumes, that you're organized enough to know up front which set of poses you want to work with in that session, which probably eliminates most people most of the time :-)
Turtle ( ) posted Thu, 03 April 2003 at 9:52 AM
I bought PBoost and thought it would be good to orginize the stuff. But I have win2000 and can't switch in poser and found it was very confusing and my sysmtem didn't like it on poser. When I bought it I knew I couldn't switch in Poser, but I thought the program, would orginize the files. Then I relelized I would have to do that.:O( My poser files are all over the place. Outside of poser I have pose files I take out and put back in when needed. I use to just delete files I wasn't using, but now I can't find anything on the tons of CD's I have. I'm so damn old that it's a wonder I remember my name when I get up in the morning!!! Then to try and remember where things are is terrible. Remember Henry Fonda in On Golden Pond= said" You think getting old is funny? Somedays I don't even know if I can pee" :O) Good Luck what ever you try. Did I just write something?????
Love is Grandchildren.
Phantast ( ) posted Thu, 03 April 2003 at 3:40 PM
Suggestion: Create a subdirectory called "Little_used". Select all the pose folders you very seldom use and dump them in there. Probably there are only 20 or so that are really useful all the time. Of course, now you can't get at them from Poser. But when you find you really want one of them again, move the folder back into the main library. It saves sanity.
BluesPadawan ( ) posted Fri, 04 April 2003 at 6:42 PM
I just purchased PCBoost and at this point not sure how effective it's going to be for me. I ran the compatibility thingie and it indicates that I should be able to switch back and forth...well duh, it doesn't. I'm running WinXPPro. If I can think something through enough in the beginning to organize the stuff, and work from those folders that are loaded, I'm fine. But if not, I have to save my file, close Poser, open PCBoost, move the stuff, open Poser, open file and start all over again. I haven't even looked at the Deep File Editor yet except to see...yep, it's there, too complicated for this old person....Leah, I hear ya hun!
PeterWahoo ( ) posted Fri, 04 April 2003 at 7:13 PM
Geesh, just spend some time running CorrectReference to fix the problems with the texture references. The problem was caused by artists who didn't know enough to put things together correctly in the first place.
BluesPadawan ( ) posted Fri, 04 April 2003 at 7:31 PM
I did spend some time with it Peter, and it did the corrections of which there were only three file directories that needed attention. My problem is that I can't use it and Poser at the same time to switch back and forth. It is indeed a time saver, and is a lot quicker than manually moving from window to window...but it's still new enough to me that these old bones need to take more time to try and make it work the way I want it to work. :)
PeterWahoo ( ) posted Sun, 06 April 2003 at 1:39 AM
You don't use CorrectReference when you use Poser. You fix the texture references, then you run Poser. You might want to spend the necessary time to fix all your texture references first, then fix each new item as you install it.
