Sun, Feb 2, 6:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: WHY DON'T POSER OPEN THE P4S I SAVED IN THE LIBRARY?
Artist3D ( ) posted Thu, 25 May 2000 at 11:26 AM ยท edited Thu, 23 January 2025 at 3:09 PM
Poser is SO Darn Wacky!It changes how it works EVERY time I use it.I hope someone can tell me WHY when I open Poser and try to load a figure I made and stored in the library,it DOES NOT look like the figure I created?I dont get it.Can anyone help?This also happens if I Import a Pz3 I made.The Figures face takes on a standard look,not the way I saved it.Thanks.
JeffH ( ) posted Thu, 25 May 2000 at 11:43 AM
If you are replacing a figure with a figure from the library, it will take on the pose of the previous figure (including facial MTs). Try opening a figure into an empty scene.
Artist3D ( ) posted Thu, 25 May 2000 at 4:19 PM
Thanks Jeff,but I did and the same thing happens.What am I doing wrong?
JeffH ( ) posted Fri, 26 May 2000 at 12:56 AM
I'm really not sure, more detail is needed.
CharlieBrown ( ) posted Fri, 26 May 2000 at 8:12 AM
Just out of curioisity, are you: 1) Using an unpatched or early version of the patched Poser 4? 2) Saving custom figures/scenes using multiple "figures" (i.e., conforming clothing, or "composed" characters)? This SOUNDS like what I had happen with some of the middle numbered patches when I tried to save characters with clothing. If that's what's happening, download the latest patch (MANUAL install version!!!!) from either Ghost Effects or MetaCreations, and the problem should go away for NEW figures, but the saved ones are PROBABLY toast.
MadRed ( ) posted Fri, 26 May 2000 at 8:38 AM
If you're going to save Figure 1, be sure you have selected Figure 1's Body before saving the figure to the library. This will ensure you save the pose, morphs, props etc. with the figure. If you have selected only the Head, I'm not sure how the rest of the figure will react upon reloading, but the Head should save fine. (Partial poses? I need to look into this...) BTW, I have had great success saving figures with conforming clothes etc. like this. My library overfloweth.
CharlieBrown ( ) posted Fri, 26 May 2000 at 8:51 AM
Mad, I had no problem saving figures with conforming clothes myself - BEFORE I patched, and have had no troubles since the "final" patch came out, but in between it was a nightmare!
