It might be time to try rendering as an image sequence, rather than AVI. Poser will probably still hang at some point, but you'll have every frame up to that point completed, and you can continue rendering from that frame later.
VirtualDub and other video editing applications can load image sequences and save them as AVI files.
There is a reported memory leak of about 4 MB lost per frame, and my own observations seem to confirm this. If you are rendering a 10 second animation in 300 frames, you will lose 1,200MB memory (1.2 GB) during the process. Therefore, if you're starting with more than an 800 MB rendering footprint, this will push the memory use over the addressable 32 bit 2GB limit and Poser will crash. Bill
That is just sad. I thought I was losing my mind. I render to TIFs ALL the time now (instead of just sometimes) when doing animations over a few seconds. Unfortunately, as someone else said, it still crashes, but at least I have the frames. What a PITA! SR3 didn't fix it for me, how about anyone else? Also, what does the RAM defragger really do and will it definitely help? Any negative side-effects of running it? Thanks! -Tim
I'm having a lot of trouble getting a 10 second animation done on Poser as Poser keeps on freezing at random frames (it's never the same frame) I've let it go for a whole day and it still will not get past that one frame. I'm using Poser 4 hair and Poser 5 conforming clothing so it doesn't need to calculate the dynamics of it and I have disabled shadows. My system specs are: Pentium 4 2.53 gHz 533 mHz FSB 768 MB RAM Windows XP Home Edition (doubt this is important but...) GeForce 2 MX 400 64 MB PCI Please help!!!
