Well done thip. Two small tips for anyone starting to play with the Grouping Tool for the first time. 1) You do not have to select different camera views, stick with the main camera, move the Grouping tool dialogue panel over to the right, and use the trackball and other controls to move around your selected bodypart and move in and out etc. 2)Near the bottom of the Grouping Tool dialogue panel is a small box which if ticked will hide other body parts while you are working. This is really handy for tricky bits. STORM
O.K., but how does this procedure differ from the results you get by just opening the map in UV Mapper, selecting a material you applied (in Poser) or just selecting the polygons, and remapping that area in Planar mapping with the right rotation (with the option to pick other forms of mapping, too)?
Wow. Great tutorial, thank you. May help with my scheme of putting hairdos on the body texture maps. I've done morphs for the texture rather than bump maps, i'll load to Free Stuff as soon as I get a map from Ghostofmacbeth... so far my own maps are awefull because I can't line up the seams properly. This "visual" tutorial is really easy to grasp.
