Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1150645
If you want to make a body part invisible, copy the lines below and paste them into notepad, then save it with a .pz2 extension in any Pose folder. To make a body part visible, change the line 'off' to 'on'. --------------------- { version { number 4.01 } actor yourbodypartname:1 { off } } ----------------- If you want to add more body parts, duplicate the lines actor yourbodypartname:1 { off } and add them in with new actor names. The names MUST be exactly the same as the parts of your figure. I posted a thread for a technique which will affect any figure, by making the transformations affect only the BODY. See the link to that thread. There's an example you can copy and paste. But this is not for textures, (although it can be modified for them). This is for transformations like, scale, trans, rotate, etc. What are properly referred to as 'SET' files. It is possible to use one texture MAT for 2 figures if they have the same materials. macIf you make the figure invisible (either through transparency or the Visible option), it won't be able to cast a shadow.
In a recent Director's Cut thread, I described a technique to render the shadows separately from the rest of the scene, so you can apply them in post. Works great when you're using images or videos for backgrounds.
http://www.renderosity.com/messages.ez?ForumID=12425&Form.ShowMessage=1077630
Hello, Is it possible to create a mat file to make a figure invisible? (Instead of having to make each body part invisible.) I want to render the shadow seperately from the figure Also can mat files be made to work with any figure or do they have to be made for each seperately? could a mat file be made to work with michael and posette or do you need two seperate mat files?
