Forum Moderators: Staff
Zoila, You know that when you alt-click a parameter dial it returns to zero? Well, it does, and if you set a new memorized position, when you alt-click any parameter dial, it will return to whatever your new default is, not zero. This can be quite useful. Say you move the Xtrans dial to -1.00 for your new memorized position. After you've saved it and re-opened it, if you then move the figure to Xtrans -2.00, alt-click on the Xtrans dial and it will return to -1.00. mac
How can I change the default parameters of a Character, in order to set a new default position? It means, when you restore the figure it assumes the new position you have assigned it.
