Fri, Feb 7, 12:49 AM CST
Forum Moderators: Staff
Subject: Poser 4: Changing default parameters
Zoila ( ) posted Thu, 10 April 2003 at 9:58 PM · edited Thu, 30 January 2025 at 8:06 PM
How can I change the default parameters of a Character, in order to set a new default position? It means, when you restore the figure it assumes the new position you have assigned it.
Ericroy ( ) posted Fri, 11 April 2003 at 9:46 AM
When the figure is set up the way you want it, 1. Select the figure 2. Go to Edit/Memorize/ 3. Click on Figure or... select the figure and press Alt+Cntl+F Good luck, Ericroy
maclean ( ) posted Sun, 13 April 2003 at 6:12 PM
Zoila, You know that when you alt-click a parameter dial it returns to zero? Well, it does, and if you set a new memorized position, when you alt-click any parameter dial, it will return to whatever your new default is, not zero. This can be quite useful. Say you move the Xtrans dial to -1.00 for your new memorized position. After you've saved it and re-opened it, if you then move the figure to Xtrans -2.00, alt-click on the Xtrans dial and it will return to -1.00. mac
