Fri, Jan 10, 1:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Thought I understood Transparancies but must not - Help!
cruzan ( ) posted Fri, 11 April 2003 at 8:48 AM ยท edited Mon, 23 December 2024 at 3:42 AM
ok here is my material room setup - the transparancy pic is black 0,0,0 and grey for slightly transparent circle (like decoupage?).
cruzan ( ) posted Fri, 11 April 2003 at 8:50 AM
AND here is what is rendered.... What am I missing? I used this same technique with my lock on front of box and it worked fine!
Crescent ( ) posted Fri, 11 April 2003 at 11:06 AM
Try putting your Transparency Fall Off to 0. I think you have something different in your settings. Cheers!
cruzan ( ) posted Fri, 11 April 2003 at 11:14 AM
Tried that - still giving me black around lock - Also tried using a png with alpha set to invisible (black part on lock) - but P5 doesnt seem to notice and still puts black around lock. Boy, I may have to actually learn UVmapper ;-)
Little_Dragon ( ) posted Fri, 11 April 2003 at 5:45 PM
Try plugging Image_Map_2 (the transparency map) into the Specular_Value, Translucence_Value, and Transparency_Edge channels, also.
