Sat, Feb 15, 11:57 AM CST
Subject: need help with smoothing problem
Innovator ( ) posted Fri, 11 April 2003 at 6:13 PM · edited Sun, 26 January 2025 at 7:40 PM
hello, ran into this prob while making the tires for my bike. I used the rounded cylinder in the Bryce imported section. Ive tried to smooth it several times and it still has sharp edges. Anyone know how I can fix this?? thanks in advance for any help
AgentSmith ( ) posted Fri, 11 April 2003 at 7:54 PM
Use a torus instead.
AgentSmith ( ) posted Fri, 11 April 2003 at 8:07 PM
Or use the tire that comes with Bryce. OR, (a look that I kinda like is the material from the tire that comes with Bryce, applied to a plain torus. (I tweaked the setting a bit, to make it lighter, more spec and some bump.) AgentSmith
pauljs75 ( ) posted Fri, 11 April 2003 at 8:25 PM
Ever change the smoothing angle to the left of the smooth button to a lower angle value? I see from the pic that it's maxed. I think it means that angles 180 and less will not be smoothed. (I could be wrong, since I usually don't mess with that setting and just hit smooth.) Try dragging it down to 90 and see if it works.
Barbequed Pixels?
Innovator ( ) posted Fri, 11 April 2003 at 10:30 PM
thanks for the help guys, Ill try out these ideas in a bit
Innovator ( ) posted Fri, 11 April 2003 at 11:17 PM
I ended up just using the torus and booleaned it with a cylinder. AgentSmith, Bryce comes with a tire? Where is it? Ive never seen it (would have made my life easier) :-)
AgentSmith ( ) posted Fri, 11 April 2003 at 11:25 PM
That looks absolutely perfect! Tire is in the Content section(s) of the Bryce 4 & 5 CD's. It is in the "Gas Station.obp" collection (I believe that is what it is called). You have to import these collections after the Bryce installation, they aren't included in the main install. But, like I said, those tires are perfect! Great modeling job! AgentSmith
FWTempest ( ) posted Sat, 12 April 2003 at 12:23 AM
agreed... those look... well... absolutely perfect is there an echo in here? :)
Claymor ( ) posted Sat, 12 April 2003 at 1:54 AM
The other trick would have been metaballs...one positive ball cut by a negative stretched oblong...it gives good smoothed edges. But these tires are, as mentioned already, fantastic.
Innovator ( ) posted Sat, 12 April 2003 at 4:11 AM
thanks all for the great comments, Im very happy with how the tires turned out, actually I kinda hate the fact that I gotta cover em up with fenders, but oh well, Ill live :-)
lsstrout ( ) posted Sat, 12 April 2003 at 10:32 AM
Live dangerously, leave off the fenders. Good looking bike so far! Lin
TheBryster ( ) posted Sat, 12 April 2003 at 7:29 PM
Don't bikes like this have front shock-absorbers?
Hepcatbrandon ( ) posted Sat, 12 April 2003 at 8:38 PM
The bike looks great. you can smooth all you want but it won't get rid of the edges being jagged. the smooth function only gets rid of the appearance of polygons ON the surface but the straight edges that appear against the background on the edges of your tire are unaffected. a little hard to put into words, hope it makes sense
Innovator ( ) posted Sat, 12 April 2003 at 9:06 PM
Bryster, the front shocks are inside the suspension housing, which is what is connected to the wheel, you dont see em in custom choppers, just stock bikes ;-)
TheBryster ( ) posted Sun, 13 April 2003 at 3:55 AM
Innovator: Thanks! Ya learn something everyday!
