Mon, Nov 25, 5:30 PM CST
Subject: Obj.files poser4
FantastArt ( ) posted Sun, 13 April 2003 at 4:35 AM ยท edited Mon, 25 November 2024 at 3:56 PM
Hallo Everyone! I always have trouble to open files when there is no rsr file together with the objekt file.The program can not find the obj.file.I tried everything.What's wrong.Can somebody help me please???!!!
thgeisel ( ) posted Sun, 13 April 2003 at 5:50 AM
it has nothing todo with the rsr file.the rsr file is a copy of the obj file created by poser itsself. the common problem is ,when the ojj file is not in the correct subfolder. If you open the cr2 file which belongs to the figure with a editor( notepad or similar) on top you will find the path where the corresponding obj file should be. move the obj file to that subfolder
PeterWahoo ( ) posted Sun, 13 April 2003 at 6:07 AM
Or you can look at the error message. Chances are it will tell you exactly where it expected to find the geometry file.
FantastArt ( ) posted Tue, 15 April 2003 at 12:39 AM
Hallo Peter!
Thank you very much for your message.
I tried this and I did exactly what you said.The geometrie file is in the correct folder but still the same problem.The objekt file can not be opened.I have this problem only when there is no rsr file together with the obj
file.
nicola
PeterWahoo ( ) posted Tue, 15 April 2003 at 8:24 AM
Hmm that sounds weird. If you have the geometry file, it should automatically create an rsr file in the proper geometry folder. We often delete the geometry rsr file to fix various error messages.
FantastArt ( ) posted Wed, 16 April 2003 at 4:17 AM
See, I don't understand either.
Do you think it has something to do with the language.
Because my Poser4 is German and most of the files are English...The englisch poser is spellig character instead of
the german Figuren, for example.That's why I allways have to place files by my self.
PeterWahoo ( ) posted Wed, 16 April 2003 at 9:41 AM
OH! I think you have the key to the problem there! As you know, some folders are named differently in German. You might not be able to easily figure how to fix this particular problem. I'm in the US, so I'm not able to help at all. Best of luck.
FantastArt ( ) posted Thu, 17 April 2003 at 1:02 AM
Thank you Peter!
PeterWahoo ( ) posted Thu, 17 April 2003 at 8:56 AM
Here's a wild guess. Is there are readme file that would tell you where the geometry file belongs? If so, make a folder in geometries, with the name exactly as described in the readme file. Do NOT translate to German. That is my last, best, most hopeful suggestion for you. I'm sadly out of my league here.
