Thanks PabloS. That's a good tip. I hadn't tried that. I just wanted to get the JCMs so I went straight for the unmodified cr2.
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1047807&Form.sess_id=6729129&
The backfacecull is a P5 problem, not necessarily Judy. You'll get it with any cr2 saved in p5. see the link for more infoAttached Link: http://arcana.daz3d.com/tutorial.php?id=46
V3 Clothes fit Tutorial is at this URL. Here are some additional hints: 1) Set the JPs in Mannequin AND clothing to V3 before Tailor-ing. 2) In Tailor -- After adding the V3 morph to the clothing, set it to 1 before Tailor-ing in any other V3 Morphs. Hint 1 is most important, make sure that the JPs in the clothes and the base figure are consistent.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Sorry if this has been pointed out before. I tried using Vic 3 with Tailor recently for the first time and discovered that Tailor doesn't like the Vic 3 cr2. Here's how to get around the problem. Open your Vic 3 cr2 in a text editor and save it with a different name (such as "Vic 3 for Tailor") so you won't be modifying your original file. Search for "//". Wherever you find a line that has "//" in it, delete the whole line. There are quite a few of these lines. They're just comments inserted by DAZ to mark which morph channels are reserved for them and which are for the community. You won't cause any problems by removing them. When you're done, save the file and you should now be able to use this new file in Tailor without any trouble.
