Forum Moderators: RedPhantom
Hi Ed, no this is for V2. I'll try throwing in the buttocks and see if that works. I have made skirts like this before (without the buttocks) and not had probs, but maybe the way this mesh is shaped requires it. When it comes to Joint Parameters, I know the basics - and there are some tutorials to be found. I have looked for more advanced tutorials on jp settings but have not had any luck finding those. If someone has a more advance tutorial out there, please let me know - particularly if it deals with setting up jp settings in Poser clothing.
Rob
If you show me the mesh in wireframe I can explain it
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
lynnJonathan - I am using a similar set up, with ghost body parts for the thighs instead of spliting the mesh into those body groups. Normally it works fine. This time, however, not so well... :O)
Thanks guys :O)
Okay, your mesh looks fine. You should know that this is typically a pose no Poser skirt can assume set up this way. You would have to have the skirt be like a mermaid tail to fit the legs crossed. The poke through is happening when the joint spheres for each leg collide. You could try making the speres smaller but you might bebetter off with correcting morphs, jcm, or just a leg cross morphs. Poser was never really designed to handle anything like skirts. The original skirt design for Poser was cooked up by they guys at Daz when at Zygote as a work around. It isn't a very flexible and agreeable item of clothing to work with. I think morphs might be your best solution.
-Anton, creator of
since 3-13-07
Corrective Morph. You'll probably need a corrective morph for a tough pose like that. I call these tricks "SuperConforming" when the morphs are tied to joint channels through EMC and work automatically. The parameter that is messing with you is the side-side in the leg (or butt) if. It's almost impossible to get a joint setup on a skirt that works in every pose. Once you create the corrective morph you will want it setup so it's not effected by joint movements. Hack the CR2 so it is the very last channel in the list. Even below the bend dials. (No not the Poser 5 dial sort thing. Cut-n-paste the channel in a CR2 or text editor. Like V2's "Knee bend Fix" morph. You can attach it to the thigh zrot channel if you want to make it automatic.
Heya Nerd, I believe I follow what you mean. I will give it a try and see what happens. If I run into problems, I will ask you for some more info. Thanks. BTW, I just want to say thanks again to everyone who has offered me help on this. IMHO, that is what makes this forum such a great place to hang. Rob
Yep, it is the dress that comes with Glamorous Vickie, and also is in the Glamorous Resorts set, and it does have JCM in it. One of the JCM morphs is just for poses like this, it adds a little room when both legs cross over, and it has limits set to stop it from working backward when it is run the other way. There are actually 4 morphs for JCM, some have more than one operator, plus a couple-three manual "helper" morphs. It is never easy! I also included the blank injection channels in the dress, to put it another way I didn't take them out of V3 CR2 when I used it ;-) , this allowed me to come back later and add some more helper morphs, which are in the free update at DAZ. I think this is a good idea for any V3 clothing, incidently.
Just wondering, cause I sure would like someone to explain them to me. :O)Normally, I do okay. I admit, I don't really understand jp settings but generally if I mess around with them enough I get good results. But for some reason I can not get this skirt to lay right. The biggest thing is the bottom wants to curl in at the thighs. Nothing I try fixes that without messing something else up.
I am using just a solid hip with the thighs added in as ghost body parts. This has always worked out well, and the skirts I have done in the past have posed nicely. But try as I will on this one...
