Tue, Feb 18, 6:33 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Feet stuck to the ground in Poser 4? Help!
TheHookUp ( ) posted Fri, 18 April 2003 at 12:22 PM ยท edited Tue, 26 November 2024 at 6:33 AM
Hi, there. I'm new to Poser. Just got Poser 4 really cheap in a software store. Didn't have the money for Poser 5. When I open a model in Poser and I select the thigh and then use the Bend dial, instead of the leg coming up, the thigh just rotates and messes up. What gives? Are the feet stuck to the ground or what? What can I do?
dialyn ( ) posted Fri, 18 April 2003 at 12:26 PM
Attached Link: http://www.fallencity.net/lore/p-h-start1.php
You need to uncheck Inverse Kinectics for the legs. Look at the example on this link. Poser 4 and Poser 5 work the same in this case. Hope that helps.
TheHookUp ( ) posted Fri, 18 April 2003 at 12:28 PM
Oh, that was easy! Thanks a lot, dialyn. Appreciate the quick reply.
dialyn ( ) posted Fri, 18 April 2003 at 12:29 PM
You're welcome. :)
