Sat, Jan 11, 11:12 AM CST
Subject: Where's the texture path?
d4500 ( ) posted Fri, 18 April 2003 at 4:21 PM ยท edited Mon, 02 December 2024 at 11:49 AM
Is there a path hidden inside certain poser files for texture files? For example... the obj path can be found inside the cr2 file.
SWAMP ( ) posted Fri, 18 April 2003 at 4:30 PM
Yes,in the cr2,pz2,etc. Are you thinking about changing the current path? SWAMP
tasquah ( ) posted Fri, 18 April 2003 at 4:59 PM
in the cr2 if its there its at the very bottom. Just use word pad and do a "find" useing " runtime " as your search word .
d4500 ( ) posted Fri, 18 April 2003 at 5:03 PM
Thanks. I just wanted to see how they came up with paths/design.
Chailynne ( ) posted Fri, 18 April 2003 at 6:26 PM
You can also use something like p3do explorer to find the texture path name. I've had to do that with some of my older items that I can't remember the folders to anymore. LOL
gstorme ( ) posted Sat, 19 April 2003 at 2:31 AM
Actually all files (pz3, cr2, pz2, obj) can be read with a text editor. I like gvim (http://www.vim.org), it is very fast and lightweight, but there are (usually free)alternatives as gvim is more for Unix buffs :). I use gvim on Windows as it automatically converts between formats and saves in the original format. You may consider to get and learn to use such a text editor because looking inside these files is the best way to understand and hack problems you cannot fix with Poser. I use gvim very often to fix paths inside these files. There are other threads about text editors. Use search to find them.
