Always a good idea to make backups of your library files. When they get kinda large Bryce tends to corrupt them. A beeter way to save models is to save each model in it's own scene file (.br5) then when you need it go to File/Merge then select the scene file that contains your model. When you save the model delete the ground plane or when you merge it you will have multiple ground planes.
not there catlin.... i fear they are gone forever. Let's all have a moment of silence..................................................................................................................................okay. back to work. Let this be a lesson to all who cherish their models and presets.
brholte, happened to me with skies, now I keep duplicate folders, bikermouse might be right if you use XP, a system restore will bring them back, its worked for me a couple of times...sorry for your loss, I can sympathize...:[
Bryce Forum Coordinator....
Just for the hell of it.......try clicking on your white squares and see what happens. You might find that if anything comes up you can re-save it........
Sorry to hear this, But I'm glad I read this as it serves as a warning, I have loads of models saved, as I tend to create them individually to pull into a scene. So now I know I'll be more careful.
http://joevinton.blogspot.com/
Tresamie: Excellent suggestion!!!!
Might also try looking for some program called "Bryce Librarian". I still haven't got it setup though, but downloaded it. (I guess I haven't really filled up the library yet.) Supposedly it allows you to add more directories in the library. Which means you'd be less likely to hit the ceiling. The program needs some kind of visual basic code as well to run. You might need to download that too. Sorry about the loss of all the work, but look at this as an opportunity to start anew.
Attached Link: http://www.wolfiesden.com/flash/main/frdownloads.html
This should be the link for Bryce Librarian. Hmmm...Your friendly neighborhood Wings3D nut.
Wow, I can't believe how many spelling and grammar mistakes are in that paragraph :-| Okay, what Bryce Librarian does(from what Paul says) is what I'll show you how to do. There are 2 ways to organize your files. You know the arrow you click in the presets that asks you what category you want to go to, Users or Installed? To make another section there, look in the Bryce folder, then go into Presets-> Objects. Make a new folder. When you relaunch Bryce, it'll be there. To make another sub-category, look in the Bryce folder again, then go into Presets-> Objects -> User. Duplicate User.obp and name it something like User2.obp or something else. It has end in .obp. There will be a sub-category there, but it will have the large quantity of models that is in your other section. You'll have to delete them. I'm guessing that's what Librarian does, so it will work on any version of Bryce(as long as the paths are the same.)
You need to copy a presets/objects subfolder into the previous folder(go back one, paste,rename, copy/cut back to the place you got it from. Go into Bryce, delete whatever is in it and add your new stuff.............
It just happened. I opened up Bryce5, like I always do, went into my object presets which where just yesterday full of time consuming models I spent countless hours making. Suddenly, I realized about %95 of them were replaced with flat white boxes!!!! They're all gone!!!! WHY!!!!!!!!!!!
