Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
I had the bump cranked up when I was trying to debug the problem. I just tried taking it down to make sure it isn't the cause and it looks like it doesn't effect it. Basically, for me, clicking "seamlessly" for a tiled texture map in the bump channel doesn't seem to do anything. It does work in the color channel. Haven't experimented with other channels. I recently installed the 'fishnet' shader plugin and may uninstall to see if that is the problem. I'm not using it in the shader but who knows. Thanks for the warning about bump >100%, though. I'll keep it in mind. And it was worth checking to see if that was the issue ;-). Marc
Hi, Kix, (Guess I can't post the .car so I'll email it). However, it is simple for me to create this from scratch. Given how reproducible it is for me and the fact that no one else sees this, it must be something to do with a bad plugin or a corruption in my files rather than a carrara bug. I'm using digitalcarver's anything grows, anything grooves, starbright, zenstar and fishnet. Maybe it is just a fat-finger problem. If not I'll try dropping some plug-ins to see if that fixes it or a complete re-install (ugh). Thanks, Marc
